drag suspension
My setup works well and is pretty cheap. I set the front loose and the rear tight to prevent squating.
Front: Lakewood 90/10 drag struts
4 cyl fox body springs (cut)
no front swaybar
Rear: Tokico (bullitt) shocks
FRPP "C" springs (dead coil cut)
UPR Chromemoly DBL ADJ UCAs with spherical bushings, pinion angle set at -2.5*
UPR Chromemoly Solid LCAs
This will give enough weight transfer to hook up and pull the wheels up.
he said drag suspension....
no front swaybar
no front swaybar
Suspension:
Fox-body 4cyl springs(NAPA #270-3060) up front w/ Lakewood 90/10 struts
Fox-body V8 rear springs (cut)
KYB AGX adjustable rear shocks
Airbag in RR spring
No front swaybar
No rear swaybar
UPR sub-frame connectors
UPR Pro Series Lower Control Arms, solid/spherical ends
UPR Pro Series adjustable uppers, spherical ends
Jegs Poly axle bushings
Torque boxes welded
No quad shocks
im doing this with a stock motor... 4.10s and an o/r x pipe
i have stock springs all around 90/10s, 50/05s and summit uppers/lowers... but see my other thread about what i did to the control arms, id get something better for a control arm... listen to jayc and 02gt4.6 about the CAs
