I was just wondering what you guys were typically seeing for a boost increase as you dropped pulley sizes.
Basically, I'm running a 3.33" pulley right now making about 6-7lbs (390rwph) and I'm trying to decide whether I should drop to a 3.125 or a 3" pulley.
The most I would want to pick up is aound 3lbs.. Do you think I could get this down with a 3.125?
well I know my setup is already off from other peoples... I think it probably has to do with the 5.4 because most people with an S-trim, power pipe, FMIC and 3.33" pulley are normally seeing more than 6-7#s.
hmmm maybe that is normal? It just seems like everyone is getting some much more boost with this setup... either way jvog you should drop a pulley size this weekend so I know how much boost I'll pick up
Haha I'll drop a couple pulley sizes when I drop my motor in, but that won't be for a couple of months. I think my boost numbers are really low, and I did a leak test on my setup and its not leaking anywhere.
