5k$ Engine?
Old May 6, 2009 | 10:01 PM
devongarver's Avatar
devongarver
Originally Posted by Bman2000
personally if your gonna spend the money buy a long block. its like 3k for a short block plus 1500 for cnc heads, then you need to add gaskets timing chains and put the sob on. your probebly looking at like4700-4800 for short block and then buying the heads and crap, vs 5000 and having it all done by pros and sent to your house...i dont know about you, but im really good with my hands and id still pay the 300 bucks when im talking about 4k in parts alone(that 300ish is just to do heads and timing in labor not including the build of the short block, its a guess i could be completely wrong)...better safe than sorry the way i see it.
Ya but im not gonna get the ported heads, if i do anything im getting the new trick flows for sure. So if i could find a longblock with those heads and they will do whatever cam i want then hellz yes thats what i'd do.
Old May 7, 2009 | 07:36 AM
Mustang_NTriangle's Avatar
Mustang_NTriangle
Originally Posted by 99BlackPonyGT
i was always told high comp. for FI, and low comp. for a spray car....is that not how it works?
my 460 is going to have about 8:1, and im going to spray the **** out of it...200+ plate kit
With KB's setup you want to run a low 8.5 compression ratio. For centri blowers you can run stock compression unless you are doing crazy boost run like 15 or more psi you would want to go lower with compression.
Old May 7, 2009 | 11:50 AM
JJ03MustangGT's Avatar
JJ03MustangGT
you got that backwards! nitrous and high compression go togethor like a hooker and syphylis. blowers need low compression to run high boost.
Old May 7, 2009 | 09:20 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
ok thanks
Old May 7, 2009 | 09:24 PM
Bman2000's Avatar
Bman2000
i would think mmr would be able to do trick flow heads at some point soon, and i cant imagine them being to much more expensive than cnc heads?
Old May 8, 2009 | 09:25 AM
99BlackPonyGT
think i heard 2k at summit but dont quote me
Old May 8, 2009 | 10:16 AM
devongarver
ya i got quoted a pretty sweet deal through cushman for head, cams, intake...im leaning towards that route right now, maybe just do that and get some suspension work done this year, and do a shortblock next spring.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
