Procharger and Typhoon Manifold or KB 2.1?
Alright, now there's a lot of planning here, and nothing is set in stone, but I really want the most raw setup possible on stock internals.. but willing to take suggestions on different routes.
1) I've been looking into Professional Products Typhoon Intake Manifolds (which look awesome polished and supposedly are good for 20rwhp).. and coupled with a P-1SC HO S/C from procharger in a polished trim, I could A) have great performance with a nice number around 400rwhp, and B) have a great polished theme under the hood... leads to more mods like polished valve covers, polished steeda radiator cover.. you get the point. Also, couldn't I run a higher rear gear ratio like 4.10s because my torque peak would be later in the rpm band with a centrifugal s/c?
2) Now of course there is the famed 2.1L Kenne Bell S/C. Obviously great power and torque all around, and it comes with an intake manifold as well as all the other goodies (injectors etc.. same goes for procharger minus the intake manifold, hence typhoon). After looking at lots of choices, I'd probably run a 3.55 rear gear. Is KB overhyped as far as 2Vs go, or is it really just the best of the best?
Opinions? Suggestions? Thanks in advance!
It looks like procharger is winning here.. I checked lethalperformance, and they only offer the P-1 s/c or the P-1 Stage II. Is the D-1 that much better that I'll even notice a difference? I just plan on running 8psi, because with my other mods (headers, intake manifold etc) I'll be near the 400rwhp mark.
Go with the KB. It's not any harder on the internals like someone stated above because it has a bypass. KB are much cooler and the procharger brackets are garbage. If you ever get to where you want to build alot of power that thing is going to flex like a yoga instructor.
Kenne Bell FTW! it is a complete kit even right down to the tune. i just recently dyno tuned mine @10psi 16.5 degrees of timing and a/f around 11.3-11.5 which is very safe. and the whine under boost is awesome.
