would the height on 315/30's look to short on my 18's
The sidewall would look fine. The difference between 30% and 35% is hardly noticeable given that it comes out to just over a centimeter. If you have 35 up front and 275 or smaller width, I would say it would look more than fine
No man it looks fine thats what i have on the back of my car heres a pic.....
https://mustangforums.com/forum/memb...re16190-a.html
315/30/18" tire = 25.6" so is actually 1/2" difference between the two in sidewall.
Either of the above sizes will fit fine on an SN95, but "may" have some fender/liner contact if off-set is not correct. This really comes down to personal preference, as the lower sidewall will make your ride a bit harsher. This is something you need to decide
Jazzer
OK, a bit of miscommunication/misunderstanding here
The difference between a 275/35/18" and 315/30/18" is zero or inperceptable. An above statement would seem to suggest that the difference between a 30 and 35 series, was minimal.
Just wanted to clarify so as not to cause confusion for those following thread.
....as you were
Jazzer
....as you were
Jazzer
