Im not getting this?
Old May 22, 2009 | 01:43 AM
RyanK's Avatar
RyanK
Default Im not getting this?
I've read the pi right up a billion times and i still dont understand, If i bought patriot or romeo heads with cams no intake could i just bolt them up and go or do i need all the gaskets and other junk :s
Old May 22, 2009 | 03:18 AM
RyanK's Avatar
RyanK
Nvm i think im starting to you need the gaskets instead of buying it all seperate can i just use this kit? http://cgi.ebay.com/ebaymotors/CYLIN...Q5fAccessories
Then all i would need is the heads,cams,intake if I have that kit and the intake was already tapped right?
Old May 22, 2009 | 07:10 AM
4.698GT's Avatar
4.698GT
patriot is a brand of head. Romeo is a casting style that ford designed. Windsor is the other casting style. Patriot will use one of these two casting styles.
That kit is what you would need if you are swapping the heads cam and intake. Depending on mileage, you may want to look at a kit for the tensioners, chains and guides.
Old May 22, 2009 | 01:22 PM
RyanK's Avatar
RyanK
yeh, I know romeo's are the ones that you can use your stock valve covers and the patriots i were looking at were romeo's but the thing i dont understand is once i have heads,cams,intake *that is tapped with the crossovers* what else would i need?
Old May 22, 2009 | 02:34 PM
03GeeTee's Avatar
03GeeTee
a tune
Old May 22, 2009 | 02:51 PM
RyanK's Avatar
RyanK
I know so all i need is the headswapping kit, heads and cams, tapped intake and im done? for the whole install?
Old May 22, 2009 | 02:58 PM
black35th's Avatar
black35th
*edit* I'm a retard.
Yes, it looks like you should be good to go.
Old May 22, 2009 | 03:01 PM
black35th's Avatar
black35th
Wait, what cams are you going with?
Old May 22, 2009 | 03:15 PM
RyanK's Avatar
RyanK
probably romeo heads with like stage II cams or blower cams,
Old May 22, 2009 | 04:03 PM
black35th's Avatar
black35th
Well, with all stage 2 cams (except HiTech) you're going to have to upgrade valve springs. Unless you're getting the Patriots and then they come with them.
