Speedo prob
Old Jun 1, 2009 | 09:43 PM
2000VertGT's Avatar
2000VertGT
Default Speedo prob
So I started realizing that when I'm doin like 5 over the speed limit, everyone is zooming by me. So I had the wife drive in front of me and find out that my speedo is 9 or 10 mph off (She doing 70 mine reads 80). To the best of my knowledge its the stock gears, certainly doesn't feel like lower gears (Anyone from Tampa wanna do comparison sometime?) Anyway, question is, do I have to buy a tuner to get my speedo correct? Don't get me wrong, I would love to have one but gotta wait for the funds to come available.
Edit: wheels/tires are stock 17" rims with 245/45 sumitumo (sp) which I'm pretty sure are stock size, correct me if I'm wrong.
Old Jun 1, 2009 | 10:01 PM
mustangman03's Avatar
mustangman03
to tell if it is the stock gears you can jack the car up and spin the dirveshaft and count how many times it takes to turn the wheel one revolution example you spin the driveshaft 3 times to 1 revolution of the wheel axle ratio is 3.00:1 now the stock axle ratio is 2.73:1 for auto and 3.27:1 for maunal hope this helps
Old Jun 2, 2009 | 07:14 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
^ correct
To calibrate the speedo you need a tuner to input the tire diameter and final gear ratio (rear-gears)
Jazzer
Old Jun 2, 2009 | 01:43 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I believe that on the new-edge models both the manual and automatics came from the factory with 3.27:1 rear ends--I know this is true for the '03 and '04 models, and believe it's the case for '99 through '04. The '03 Mach 1 had 3.55s...
jwog666
Dec 27, 2021 08:09 PM
67LimeCoupe
Nov 25, 2015 08:55 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
