Tell me about Nitrous set ups! I'm new to all this..
I would never use a torch of any-type/fuel to heat up a compressed gas bottle, thats just asking for it to fail. If you need/want a heater get a damn heater, dont ever use a torch to heat up your bottle, you can over heat a spot and create a weak point and it can fail at that point. I Have Seen It Happen. Its not a pretty thing to watch a friend get blown back from his car. Trust me on this, its not a good thing.
2. Expensive? IDK shop around. Or install it yourself. Its not that bad, just time consuming. Its a harder install vs a dry kit. Dry kit will be easier to install.
The entire kit for me was $400 dollars. I didnt need a window switch and you dont need a purge kit. It was a grand total of $400 dollars. There are some cheaper bottle warmer for under 100 dollars on dynotune nitrous website.
wet and dry kits both have advantages and disadvantages. i prefer dry kits on these fuel injected mustangs and let you know how mine is set up and works. if you use a blow by system, where nitrous is spayed before your maf, it your computer compensates and adds more fuel for you. this is more reliable in my eyes than a wet kit, because, in some cases, wet kits can puddle in the intake manifold leading to it being blown off. i started with a 50 shot and made a couple of passes on it. building up the confidence to go to 75, but does anyone think i need to swap to 1 step colder plugs? if not, im gonna test it tonight.
