Finding TDC
Old Jun 18, 2009 | 09:28 PM
mustangman281's Avatar
mustangman281
Banned
Don't worry about taking the engine apart just pull it apart.
For ease of install turn the crank to where the keyway is at 9 oclock. Then install the heads, followers, lash adjusters then bolt the cams in making sure the keyways point towards the crank. That will get you close enough to put the chains on. When installing the chains do not turn the crank only turn the cams to get the marks to line up.
Old Jun 18, 2009 | 09:41 PM
jvog's Avatar
jvog
I am leaving the cams in the head when I pull them off the motor...
Old Jun 18, 2009 | 09:57 PM
mustangman281
Banned
Then you better turn the crank till the keyway is at 9 oclock. If you try to do that at TDC you will bend your valves.
Old Jun 18, 2009 | 10:12 PM
jvog's Avatar
jvog
Really, I saw that people do it at TDC when I was looking around thanks for the heads up. So I don't need to mark anything when I take it off?
Old Jun 18, 2009 | 11:00 PM
mustangman281
Banned
Nope you can mark the chains later by folding them in half and marking the ends.
Old Jun 19, 2009 | 07:40 AM
Chris98Gt's Avatar
Chris98Gt
You can rotate the motor around so yo can pop all the cam followers off then all the springs will be keeping everything closed. So no matter where the crank is you can take the chains off and spin the cam all you want, it wont move the valves.
Old Jun 19, 2009 | 04:15 PM
jvog's Avatar
jvog
Oh alrighty. Now not to sound like a complete idiot, but can you explain the purpose of marking the chain/folding it in half. I'm just trying to know everything about what I am doing..
Old Jun 19, 2009 | 04:21 PM
Xemeth's Avatar
Xemeth
It's so you know which link of the chain goes to which tooth on the cam gears. You'll see little dots machined into the gears to mark which tooth the marked chain goes on. The chain should have two links, one at each end, that's a different color than the rest. If the color has worn off, that's when you fold it and basically make new marked links.
Old Jun 19, 2009 | 04:42 PM
jvog's Avatar
jvog
So, if I am making new marked links, what is the point of marking them. It just it sounds like if I am making new ends couldn't I just throw the chain on there. I know I am missing something lol.
Old Jun 19, 2009 | 06:53 PM
mustangman281
Banned
https://mustangforums.com/forum/4-6-...6k-beware.html
