Need help bad!!!!!!!
Old Jun 20, 2009 | 05:04 PM
01GT4.6's Avatar
01GT4.6
like it was said earlier, suspension would do wonders. But it's hard to say what you are doing wrong without more info. I would suggest driving around the waterbox and back into it. Turn the tires over in the waterbox (just enough to get them wet, don't sling water all up in your wheel wells, it'll drop down on the tires when you launch). Pull forward, out the water, and do a nice burnout. IMO there is no need for a 10-15 second burnout. I do a 4-5 second burnout, release the brakes and roll up while burning the tires (trust me if you do it right there will be enough heat and smoke to make you feel like John Force ). I also don't see any benefit in running 15psi, it's not like the tire is designed to wrinkle. Underinflating the tire will make it try to ride on the outer edges. I got a 1.60 60' with 21.5 psi and a short burnout as I described.
Track prep and how you work the clutch (assuming you have a standard) play a huge role as well.
Old Jun 21, 2009 | 07:26 AM
jeff37110's Avatar
jeff37110
Thanks guys, Im getting my control arms put on today.. Also is the eibach pro kit hurting me? Im going to get some fox body struts and shocks today also.. To answer the track question I talked to some local people and he doesnt prep the track anymore for test and tune night only on saturday night when the class races are going on...Last year he did prep the track so..I guess I will be driving the extra minutes to go to another track which is not a big deal.. Let me know if the fox body struts and stuff are bad idea or the pro kit. Thanks
Old Jun 21, 2009 | 07:52 AM
mrtstang's Avatar
mrtstang
I have the pro kit! I don't think it i made much difference either way, except i got a little less wheel hop.
Old Jun 21, 2009 | 08:15 AM
mustangman281's Avatar
mustangman281
Banned
Where in TN and what track?
Old Jun 21, 2009 | 08:44 AM
ddmsgtr1's Avatar
ddmsgtr1
Are you dumping or slipping the clutch? I'm still working on it myself, but I'm slipping at least to the 60', sometimes past. The best I've cut is a 1.95, and the only suspension work I have are strange 10 ways all around. And like 01GT4.6 said, there's no need for a 10-15 sec. burnout. I usually do about 5, let off the brakes and then roll out of the gas.
Old Jun 21, 2009 | 10:42 AM
jeff37110's Avatar
jeff37110
Buffalo Valley,Tn they call it Middle Tennesse Dragway. Also Im dumping the clutch that probably doesnt help either.. IM used to full blown slicks on my fox... Just dumping and going!!!
Old Jun 21, 2009 | 11:32 AM
01GT4.6's Avatar
01GT4.6
people don't realize how much heat you can create on a GOOD short burnout. Check out my video and go to :45 (that is my nitto burnout)
http://www.youtube.com/watch?v=WBAU04OufMI
Old Jun 21, 2009 | 11:55 AM
jeff37110's Avatar
jeff37110
yea I really over did it then..Cause I did first gear then second and stayed there for 15-20 second burnout..Im going to try different track and try short burnout and go from there.. I was impressed with my et's just would really like to get off the line and dip in the 7's in 1/8 mile.
Old Jun 21, 2009 | 01:34 PM
ddmsgtr1's Avatar
ddmsgtr1
Definitely try slipping the clutch, it's worked well for me.
Old Jun 21, 2009 | 05:28 PM
jeff37110's Avatar
jeff37110
I will give it a shot next time at the track. Thanks
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
GLOCKer
Sep 28, 2015 07:36 AM
