o/r h pipe
ok, right now, idk why but the stock mid pipe hangs like an inch or two lower on the drivers side. do you think that might make it more difficult to install a new one, or do you think that my mid pipe now is just bent somehow?
I installed my midpipe. The process itself isn't terribly difficult, but doing it on jackstands, to me, was a huge pain in the ***. All you are doing is unbolting the old and bolting up the new, but access to the passenger side header bolts can be very tricky. YOu'll need a swivel socket.
The pass side was a PITA to do just because of where the header flange is, but otherwise it is pretty straight forward. With the summit pipe, I had to use my tuner, even though i was going to anyway, because the rear 02 bungs weren't even close to the where they would need to be to plug in the 02 sensors. I just used plugs to close up the rear bungs.
Also, you'll need to order a stud kit for the drivers side where it meets to the stock header. NAPA sells it. I can't remember why, but it won't sit flush with the stock studs in there. Also, a metal gasket for the passenger side. Don't use the cardboard one..if it comes with one.
Legal Question
Do I need to spend an extra 180 for the High Flow Ceramic Catalytic Converter Kit?.... on the o/r pipes? I live travel between IA/MN. Is it legal in these states not to have it. I don't want to get ticketed. Could someone Help explain this please???? or pm ME. whats the difference?
Thanks
Thanks
Thanks
Thanks
