Trick Flow 38cc Heads! Pics!
Thanks! yea, i thought it was worth a pic
LMAO!! Thanks man! BTW, read post #7
Nope, they sent you the wrong ones....see they were supposed to go to me and you were supposed to get my stock heads instead. But they sent you the one...so i'll be needing that. Thanks but seriously, im soooo jealous of both the heads and the power you will be pushing with those and the blower. Good luck man. What cams are you stuffing in them things???
Got it. well i dont want this car to idle like a pro fuel car. I want a little chop, but not too much to where it is ridiculous like you are sitting on a washing machine when its in spin cycle.. I still want a well mannered mustang. Sounds like a contradiction, but it can happen. I'll look into those cams though. do you have any links or info on those?
CMS is grinding cams specific for these heads i think. But if you contact Jim, im sure he could talk to you about what should be done to get your car to idle how you want it to and then make it so the cams are custom tailored to your heads and your setup. Because i definitly think that that cam is kinda weak on lift...the stage 2 blower cams through CMS have .530/.570 lift and thats only a stage 2 which only supports up to 600rwhp. So if youre going for that much or more, i would suggest something a little bit more aggressive than the MPH kb blower cams.
links: http://www.cushmanmotorsports.com/in...f0351c0b9910f1
I just dont think that you will be very happy with those cams as mild as youre saying that they are. Stock PI cams are .505/.534 lift...so those cams are even more mild than stock cams. So i would look elsewhere if thats really what they are.
Well at least I know not to do business with MPH. Jim Cushman made me some custom cams for my 4v and told me the specs no problem. The cams even came with a little card with all the specs and instructions to degree them.
