Restore oil treatment
I searched but couldn't find anything about this on here. I was looking at the Restore engine oil treatment that you add to a new oil change and was wondering if anyone recommends it or if I should avoid it. Its a 96 with 110,000k and if it does what its supposed to (help oil consumption and cylinder compression) then I'll use a can but if theres any reason not to then I wont.
Do you have oil consumption and/or compression problems?
That sort of snake oil is a last ditch, nothing to lose, what-the-heck "fix" to keep ghetto sleds running--there is no magic elixir that can restore worn rings or worn anything else. The best it can do is mask the problem for a while--and actually if it does makes any difference then it just means you need to start saving up for a new engine now...
