motor
Old Aug 29, 2009 | 11:57 AM
liljojo4711's Avatar
liljojo4711
Default motor
http://dallas.craigslist.org/mdf/pts/1348500043.html
what would cause a burnt valve? is it worth the $100 and the risk?
Old Aug 29, 2009 | 12:17 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
If you need new internals it would be an expensive repair. You looking for a 5.4 or it does not matter. Reason I ask is that I have a stock 4.6 short block 2004 with only 23,000 miles on it. You will need heads and timing chains and you would be good to go.
PM me if you are interested.
Keith
Old Aug 29, 2009 | 12:20 PM
liljojo4711
im looking to do a 5.4 swap. i was planning on gettin new internals anyway but i dont want to get the engine and find out the block got cracked or something. whats the worst that could be wrong with the engine after a burnt valve? i was planning on a .02 over bore anyway... maybe just some machining to square everything up?
Old Aug 29, 2009 | 12:29 PM
fisher2985's Avatar
fisher2985
should be ok. i've seen several 5.4's come in with a cylinder misfire, low comression on one cylinder. almost always turns out to be a burned valve. but since u have to remove the engine to get the heads off, most customers will replace with a used engine. (probably what this guy did) they are also bad for stripping out the spark plug holes. (not enough material at the spark plug seat)
hell u can sell it for more than $100 in scrap metal though.
Old Aug 29, 2009 | 12:49 PM
liljojo4711
ok, well i think im gonna tell my mom to get it for me for my bday and ill go from there. atleast i will have a block and crank out of the deal. any other thoughts?
Old Aug 29, 2009 | 03:15 PM
Mustang_NTriangle
Are you looking for forge it? If so, you are better off just buying a built 5.4 short block then paying for machining and blue printing motor.
Old Aug 29, 2009 | 03:41 PM
HaneyMotorsport.Com's Avatar
HaneyMotorsport.Com
Banned
99' 5.4 should have a forged crank! Later years, Ford used cast and forged....Lightnings of course have forged cranks. Regular F150, Exped, etc. could have got either one.
Casey
Old Aug 29, 2009 | 06:12 PM
liljojo4711
i dont want to just buy a motor, i want to build it
Casey
im pretty sure its not forged, its from a 99 expedition but that would be nice.
so it looks like im gonna buy it if no one says there could be major damage to the block...
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
