Air Filters???
Air Filters???
When i bought my car, it already had a cold air intake put in.. it looks like one of those $70 ones from AM or wherever sells it for that much.
ANYWAY, my air filter is now brown from all the dirt that's in it... i jsut changed my spark plugs and my air filter is definitely next on the list. Do you guys recommend any specific air filter to buy?
should i just go to a local auto store and get a replacement? or should i get the one that AmericanMuscle sells?? K&N is way too expensive... $60??!?!
will ANY filter fit on my intake tube that is on there now? the filter is in the fender
any aftermarket filter should do the same thing though... because if i buy a filter, dont i have to go buy the oil for it too? dont you always have to oil a filter before you put it back in?
this one looks just as good as the 99-04 GT K&N filter that AM has... this BBK one does the same exact thing and its re-useable. why spend the extra $20? if there is a good reason, maybe i will just cough up the extra 20 bones
http://www.americanmuscle.com/bbk-airfilter-v6-46.html
K&N is worth it. Mine was I think $50, and it came with the cleaner kit as a gift. K&N is re-usable, just clean it every k miles. If you go to advanced auto parts, they have a K&N air filter, then the stock filter. You can see a big difference, obviously. Don't be cheap on it, its worth it. My mom's was like $80, for a 04 jetta. lol
I just reoil my filter with every oil change, it is the one that came with the JLT. It is a good filter, I will continue to use it.
S&B filters
S&B filters
i guess my main question here is -- will any air filter fit on the cold air intake that is on my car now??
for instance - are the cold air intakes designed so that you can use a stock style air filter on them?
thanks
thanks
