cam horsepower help
cam horsepower help
will u guys with cams and full bolt ons, post up ur horsepower #s, im thinking of doing cams and cant decide whether its worth it or not. also please post up brand and stage so i can make a decision. thanks in advance.
Cam HP
So my car is supercharged but here is a summary....
Drive Trane Upgrades:
S.P.E.C Stage 2plus Clutch
S.P.E.C. Aluminum Flywheel
Roush Billet Short Throw Shifter
3.73 Ratio Ford Racing Gears
Granatelli 2 piece Drive shaft Loops
Performance and Engine Upgrades:
Saleen 3V Twin Screw Supercharger
Saleen 2 Stage Intercooler and Pump
Saleen Extreme Cold Air Kit
Saleen GT500 Dual Fuel pump
JDM Vacumm Line upgrade
Autolite Gapped HT0 Plugs from JDM
Saleen Extreme 113 MM MAF
Ford Racing 60lb injectors
Saleen Extreme 3.0 Pulley
KOOK’s Long tube SS Headers
KOOK’s 2 ½ SS X-Pipe with Cats
Ford Racing Tubular Axle Back Exhaust
SCT EXCALIBER 2 Tuner with custom JDM performance tune
V-10 Ford WP Pulley
Comp Cams Stage 1 SPR Blower Cams
HP is always going to be different with different dynos....so i will just say my track times
remember i am also at 5800' elevation so times are a lil slower than sea level
stock cams.....12.5 @ 112 mph
Comp Cams......11.8 @ 120 mph and the sound is badd ***
V-10 Ford WP Pulley
With cams/full bolt-ons you should see 12s EASY and be at 300 peak hp~ with stage 2s and around 290 peak~ with stage 1s(with a WAY better curve than stage 2s with stock heads).
thanks hoss, im thinking cms stage ones, or high tech stage 2's (their site says i can use stock springs just as long as i keep it under 6500) the only reason ive got an auto is because all of the manual's at the time were $4000 more and had the same mileage. gonna swap to a manual when the auto quits.
but u guys with cams keep em coming, any help is greatyl appreciated.
