got a question on my nitrous
i went to the track last night and i am running a 125shot. the bottle had 900psi, but when i used the nitrous it didnt even make a difference. is it possible to get bad nitrous? i checked both solenoids today and they both are working. The only thing i can think of is that i got bad nitrous. could someone please chime in and let me know if thats possible, or to check something else that could be the problem.
No I've never had that happen in the countless bottles I've gone thru... Nor have I even heard of it happening...
You need to tell me your exact set up... What window switch, wot set up, etc, and how its all wired... My guess if your problem is there
i just have a wot switch. both solenoids are working. i think my bottle has just air in the bottle. i just activated my nitrous, took a wrench and both solenoids have a magnetic charge when i arm the wot switch.
ya i can hear the click, and both are magnetized when wot is activated. i did some research and other ppl have had a dealer refill the bottle, and it be just air. when the bottle is disconnected and you open the bottle i heard it comes out kinda like a white smoke is that true? if it is i dont have that
How much does the bottle weigh? Full should be 20something. But... If it was working it would actually run like **** because of all the extra fuel... I've hit my switch by accident and it hardly wants to climb thru the rpms because of all the extra fuel
i dunno whats wrong, ill have to tear it apart and try to figure it out. its a plate kit so im thinkin about takin the plate kit off the intake and see if nitrous and fuel is coming out of the ports...should that be ok to do?
