Rotors
Old Oct 5, 2009 | 02:38 PM
stang23456's Avatar
stang23456
Default Rotors
Ok im having a wheel shake at around 40-50 mph on my 04 GT. Everything under the sun has been checked, suspension, balance, rims, etc... My pro shop is telling me I have warped rotors and thats causing my wheel shake. Anyone had a similiar issue with rotors ?
Old Oct 5, 2009 | 02:51 PM
Eagle2000GT's Avatar
Eagle2000GT
I had the rotors warp on my truck. It caused it to shake quite a bit (at times I thought the front end might shake loose) when I applied the brakes but it was OK driving down the road. Does you car shake a lot more when the brakes are applied?
You might check this out yourself by jacking up the car and spinning the wheels.
Old Oct 5, 2009 | 02:55 PM
Hangwire's Avatar
Hangwire
Our 99-04 GT rotors are cheap, ford cut costs there, they are the same as V6 rotors if that tells you anything. I warped mine within a few burnouts on my auto. All is well until I hit the brakes at 50+ MPH and then it shakes like a ****ing aggregate tumbler. I've.....heard.....that just giving it moderate brakes when slowing down from 100+ MPHs is plenty to heat-scar these rotors. If you are going to replace them, don't put the same old **** back on. Buy the front cobra upgrade kit from FRPP its like 400-600 dollars depending on if they have deals up or not. Make sure you get stainless steel lines as well. Sometimes when they are selling the kit for 400 it doesnt include the steel lines.
Old Oct 5, 2009 | 03:37 PM
tdcalhoun89's Avatar
tdcalhoun89
+1 to what hangwire said
When I bought my mustang the rotors were warped, swapped them out pretty easily with the help of a little PB blaster. I would also recommend some hawk brake pads too.
Old Oct 5, 2009 | 05:41 PM
nascrchi's Avatar
nascrchi
the hawk pads are awesome! I have them hooking onto some Ford Racing C/D rotors out front and stock rotors out back. I'll advice the hawk pads for sure, but I will recommend you some better rotors! not too expendive by the way, considering how it safe it is and feels. That's the first thing I bought for my car because i wanted to be sure I'd stop kinda fast if I wanted to.
Old Oct 5, 2009 | 05:55 PM
DreamerGT's Avatar
DreamerGT
me--><--- ford
Old Oct 6, 2009 | 12:20 AM
tdcalhoun89
if you don't want to mess with the calipers and do the cobra setup you can always slap some new rotors on quick, ssbc makes some nice ones slotted crossed drilled ones that work with the stock calipers
Old Oct 6, 2009 | 12:46 AM
Sxynerd's Avatar
Sxynerd
drilled rotors are for looks don't really do anything. Increasing the rotor size has more of an effect. ssbs is a decent company but it would be cheaper (if that's an issue) to just upgrade tot eh cobra brakes.
Old Oct 6, 2009 | 11:52 AM
dimebag's Avatar
dimebag
Personally I'd do the sloted stock sized rotors... But that's because my 15x3.5 draglites wnt fit over anything bigger lol
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Oct 7, 2015 07:02 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Sep 16, 2015 07:53 PM
Wombatnation
Sep 13, 2015 09:16 PM
