H-pipe
i just installed a summit off road hpipe on my 2003 gt, i got the mil eliminators and there is no check engine light, my only problem with the pipe is while you are gunning it, the exhaust makes a sizzling noise, it sounds like barbaque, is that noise normal,
i took the car to mustang magic and they checked it out, they said it was no leaks, my car is stock, they told me to put 93 octane in it, is the noises normal?
It should have burned off by now , you never know tho. You would know if there was any water that got in there since you did the install yourself , It could be some type oil or residue thats caked on the inside that just needs time to burn off. Is it only when you excellerate or mash it ?
Sep 24, 2015 09:18 PM
