anybody using the aluminum intake manifolds?
Old Nov 16, 2009 | 12:30 PM
  #21
TimmyGt's Avatar
TimmyGt
sxynerd, did you have any clearance problems when you put the new intake on or did you just get the cowl hood for looks?
and I would be looking at about $600 for everything to get the edelbrock on my car?
Old Nov 16, 2009 | 01:57 PM
  #22
Sxynerd's Avatar
Sxynerd
Another early Sn guy told me he had to cut away the fiberboard insulation right above the throttle body and plenum.
Old Nov 16, 2009 | 02:36 PM
  #23
teej281's Avatar
teej281
4.6L Section Moderator
If you already have aftermarket plenum and throttle body then you will be right around $600. If you dont, you might want to look into getting that stuff too for better airflow.
Old Nov 16, 2009 | 02:59 PM
  #24
Sxynerd's Avatar
Sxynerd
You know, I've heard the argument that unless you get the Edle elbow and 90mm maf you're just cutting off the possible air flow... I however disagree with that idea.
There are lots of turbo/blower guys with 2.5" pipe with perfect setups. Unless an individual is NA, already has heads and headers, I don't think it would matter much.
Old Nov 16, 2009 | 03:15 PM
  #25
TimmyGt's Avatar
TimmyGt
you have any pictures of the plate you made to mount your stock plenum to the intake? or any how to info about it?
Old Nov 16, 2009 | 03:32 PM
  #26
Sxynerd's Avatar
Sxynerd
It's as easy to make as it looks. Make a template and go from there. Make sure the metal is thick enough to tap and the bolts can hold securely.
Old Nov 16, 2009 | 03:33 PM
  #27
Sxynerd's Avatar
Sxynerd
Old Nov 16, 2009 | 03:41 PM
  #28
TimmyGt's Avatar
TimmyGt
lol, I totally have that same plenum!
did you use any gaskets or have any problems with air leaking?
Old Nov 16, 2009 | 03:45 PM
  #29
Sxynerd's Avatar
Sxynerd
I used RTV with no issues. I was going to use gasket paper but I forgot to buy more. It's held up just fine.
Old Nov 16, 2009 | 05:10 PM
  #30
Chris98Gt's Avatar
Chris98Gt
I used a carb gasket on the bottom and a homemade cork gasket for the plenum, and I've had no problems yet.
