pi swap/headers
Just ordered heads and a kenne bell charger for my GT. I forgot to ask keene bell when giving my app. if the long tube headers that I have will fit with the 99-04 heads. Does anybody know if the headers will fit or do I need to wait another pay check to get headers AGAIN? HAA!! I cant stop MODING
I have longs tubes on a pi swapped GT, the headers I got were for the 96-98 npi heads and they fit on the pi heads just fine, they use the same bolt pattern and exhaust port shape. You should be fine.
Thanks you guy`s. Its been a pain in the pocket book to get this stang going. Now im just waiting for comp cams to get my grind. I wish I could get a loope cam but "Comp" said "Im already pushing my rods with the 10.5.1 compression w/pi-swap", "then topping it off with a wipple." Now im wondering if I should even put on this dam k-bell?
Just keep the boost low, I'm running 8psi with PI heads, stage 2 compcams npi cams and It's been together for over 2 years now. Be very conservative with timing if you're tuning it yourself, or be sure to let your tuner know its a pi head swapped car not a whole motor swap.
