Shift Kits
Old Nov 21, 2009 | 03:30 PM
Andover Stang's Avatar
Andover Stang
Default Shift Kits
Who here has added a shift kit to there Automatic?
Any real benefit?
Thanks
Old Nov 21, 2009 | 03:53 PM
03BottleFedGT's Avatar
03BottleFedGT
huge benifit. firmer more crisp shifts.
Old Nov 21, 2009 | 05:41 PM
sonicx's Avatar
sonicx
speed'n
Any real benefit?
Thanks
Andover Stang:
Yes
If you doing it go with Trans-GO. It'll help. I wont show gains like gears or getting your car tuned but i'd HIGHLY recommend it for ALL auto owners.
Visit this thread: https://mustangforums.com/forum/4-6-...shift-kit.html
Old Nov 22, 2009 | 06:00 AM
ESABATM's Avatar
ESABATM
J-mod hands down. Look over at TCCOA in their tech articles. I did my 95 tbird back in the day and it is still going with 150K on it.
Old Apr 28, 2010 | 11:33 AM
BlueMagic's Avatar
BlueMagic
Selling a brand new one of these... if interested PM (Ill give ya a good deal). I wanna get rid of it, haha its collecting dust.
Old Apr 28, 2010 | 03:50 PM
02stang2113's Avatar
02stang2113
It seems to be a pretty good mod... i only hear good things about them. It will most likely be my next mod...
Old Apr 28, 2010 | 05:51 PM
Hangwire's Avatar
Hangwire
Dude your pushing this thing like coke on the streets of Detroit. Stop bumping old *** threads for this crap. Theres a section for selling/purchasing things learn a little forum etiquette.
For anybody who cares about the truth you DO NOT need to buy a "shift kit." Most shift kits include the only modification you need to do to your 4r70w to get both much better AND safer performance. The only mod you need to do to your tranny is something called a "J-MOD" which most "shift kits" include. "Shift kits" however often go farther than that and call for modifications that provide extremely neglegable and dangerous modifications effecting the life and durability of your transmission. The "J-MOD" is a modification to the Main Control/Valve Body of your transmission which includes porting out ATF flow holes and removing accumulator springs. This "J-MOD" is named so after the Ford Transmission Engineer that designed this modification. His name is Jerry Wroblewski and he has a full writeup on the 4r70w that covers absolutely everything about this transmission from top to bottom.
Here is a link to Jerry Wroblewski's full write-up.
Heres a direct quote from section 5 of Jerry Wroblewski's write-up.
"A lot of shift kits put a blocker ring in the 2-3 accumulators. This limits the amount of travel for the accumulator. And yes, it does result in firmer shifts. But don't do this. What is happening is this; if you remember the accumulator explanation from before, it allows a slower pressure rise in the clutch as it is applying. This accumulator stroke limiter forces the clutch to go in line pressure faster, but the way it does that is by stopping the accumulator from stroking thus ending the ramp. When you allow a shift to finish, meaning the clutch stops, when the accumulator stops stroking it puts a large shock load into the transmission and driveline which will result in eventual failure of something."
For another clearly obvious reason you should not install a "shift kit" on your transmission refer to the last paragraph on the page of section 5 regarding bypassing the main regulatory priority system.
Old Apr 28, 2010 | 07:49 PM
02stang2113
I didnt even know it was a old thread or i wouldntve commented...
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
