ford lighting MAF
Old Nov 22, 2009 | 04:34 PM
Jono 02 stang's Avatar
Jono 02 stang
Default ford lighting MAF
Can I use the lighting Mass air sensor on my supercharger set-up for my 02 mustang, because the supercharger didn't come with the mass air sensor?
If I can, do it have to do recalibration to it? Am using 42lbs injectors.
Old Nov 22, 2009 | 04:50 PM
Sxynerd's Avatar
Sxynerd
Yes and no. Yes you can use a LMaf. The maf isn't getting "Calibrated" to the injectors, the ECU is. So if your ECU is tuned for 42's then your good. If it's not, "i.e. your still running stock injectors" then you'll need a tune.
Old Nov 22, 2009 | 05:24 PM
Jono 02 stang
So I can use my stock maf, because when I install the supercharger am going to get the car tune.
Old Nov 22, 2009 | 07:36 PM
01MGGT's Avatar
01MGGT
From my understanding you at least want a 90mm Lightning MAF with a blower setup. From what I have read using the stock MAF will limit you alot.
Old Nov 22, 2009 | 08:28 PM
Sxynerd's Avatar
Sxynerd
If you're changing your maf and injectors you'll need a base tune or the car wont run enough to drive.
If you can't do that, then you can keep the stock injectors and Maf in place AS LONG AS YOU ONLY IDLE AND PUTT THE CAR WHILE YOU DRIVE. NO BOOST AT ALL!!! That'll get you as far as you need to go.
Old Nov 22, 2009 | 08:57 PM
Jono 02 stang
Is there a programer for 2V supercharger mustangs or is dyno tune the only way to go?
Old Nov 22, 2009 | 09:09 PM
Sxynerd's Avatar
Sxynerd
Who's tuning your car?
Old Nov 22, 2009 | 09:56 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Sure, Delta Force Tuning Commando.
A "dyno" tune is just paying someone to use a tool like Commando, and a dynamometer, to do what you can learn to do yourself. It's what people that don't know how to tune an engine do, and then brag about--it's like having someone else screw your girlfriend, and then you go around bragging about how good she was.
You can do the same thing, better, with a proper tuning tool, a wideband O2 sensors, and a stopwatch on deserted stretch of road--plus you will then have the knowledge base to dial in tunes for specific conditions.
If "dyno" tunes were perfect the pros would never have to tweak tunes between runs, lane changes, and morning/afternoon/evening...
Old Nov 22, 2009 | 11:16 PM
01MGGT's Avatar
01MGGT
I have started putting together the $1500 package for the vortech and I know I can throw in 42 lb injectors and Sniper has a built in option for them. I saw there was also an option for the 90mm MAF so I am wondering if I can use the 90mm MAF with my stock air intake until I get the kit built? Mre air flow should help with the cams once they are installed anyways
SteelerNation82
Mar 9, 2025 11:40 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
mweiland
Aug 16, 2015 10:59 AM
dseg
Aug 8, 2015 09:00 PM
