sn95 quarter mile times with pi heads
Old Nov 24, 2009 | 06:51 PM
kugzgt's Avatar
kugzgt
Default sn95 quarter mile times with pi heads
just wanna get an idea of what i can expect to run after my headswap with some bolt ons. feel free to list your mods
Old Nov 24, 2009 | 07:06 PM
H0SS302's Avatar
H0SS302
u should be in the 13s
Old Nov 24, 2009 | 09:40 PM
945LSTANG's Avatar
945LSTANG
low 14s, high 13s if you can drive.
Old Nov 24, 2009 | 09:44 PM
teej281's Avatar
teej281
4.6L Section Moderator
Do you already have your parts for the PI swap??? If you can fit it into your build budget, id at least do some cams with the swap, and if you can swing it...some ported heads. It will make the swap that much more worth it.
Old Nov 24, 2009 | 09:51 PM
mrtstang's Avatar
mrtstang
Are you doing just the PI heads, or the entire PI swap?
Old Nov 25, 2009 | 07:02 AM
4.698GT's Avatar
4.698GT
i swapped a pi motor with cams and stuck right around 13.4
Old Nov 25, 2009 | 10:18 AM
blee69mustang's Avatar
blee69mustang
im did low 14's with my npi heads and stock gears just full exhaust and suspension, intake and tune and good street tires 245. you should prob be able to better then that.(im sure some one wont believe me and will ask for the time slip but im not putting it up(to much work now) and if you dont believe me then fine.)
Old Nov 26, 2009 | 03:04 AM
00infernoGT's Avatar
00infernoGT
i have been able to turn over multiple 13.80's with my old setup. upper plenum, catback h-pipe, steeda tri-ax,CAI, Nitto 285/35/18's
Old Nov 28, 2009 | 05:18 PM
kugzgt's Avatar
kugzgt
i have everything for the swap im just waiting to get them pressure checked and resurfaced. cams are def a possibility...any suggestions????
Old Nov 28, 2009 | 05:55 PM
mrtstang's Avatar
mrtstang
Bullet Racing, Hitech, and CMS all make some great cams.
