broke an intake bolt!!! what should I do?
so I was taking the intake manifold off my 4.6 bird to try and stop it from leaking and the bolt right behind the two that hold the thermostat housing on broke when I was trying to loosen it. I got the intake manifold off and I already tried to grab the remaining nub that was still sticking out with vice grips and I couldn't get it to move at all.
what should I to fix this? or should I just leaving it and worry about getting the leak fixed?
I would say its that fact that the car is now going on 13 years old! it doesn't look rusted and when I tried to take it out it wouldn't move. so I tried a little harder and it snapped like a twig! the rest of the bolts came out fine with just a little force to break it loose.
http://www.amazon.com/Easy-Out-Piece.../dp/B0002UJNWE
If used carefully it will dig into the screw and start unscrewing it from the threads.
