Sub Frame Connectors ?
Old Dec 12, 2009 | 02:46 PM
atrain59's Avatar
atrain59
Default Sub Frame Connectors ?
Im shopping around for Sub frame Connectors and was wondering what ones everyone would suggest getting. I have found a set i like but there for the 04 gt and up and i cant seem to find them for a 97 here is a link to the ones i like but like i said i cant find them for a 97 mustang http://www.summitracing.com/parts/SUM-791020/
Old Dec 12, 2009 | 02:53 PM
ct_white_stang's Avatar
ct_white_stang
Nah - Go with maximum motorsports they are cheaper too. I just ordered my set.
Old Dec 12, 2009 | 03:00 PM
lizzyfan's Avatar
lizzyfan
Underboss
I installed these http://www.americanmuscle.com/7904-f...onnectors.html over three years ago and they do the job
Old Dec 12, 2009 | 03:10 PM
atrain59's Avatar
atrain59
Whats the difference between welding them on and bolting them on. Besides you can take the bolt on ones off. Is there any significant difference.
Old Dec 12, 2009 | 03:12 PM
mustangmancp's Avatar
mustangmancp
Ok...so ive asked this like three times and i dont' think ive gotten a clear answer. So do verts need subframe connectors???
Id go with the AM ones...thats what im gettin if i get them.
Old Dec 12, 2009 | 03:22 PM
Shaunmac9128's Avatar
Shaunmac9128
verts have smaller subframe connectors stock. But they are not full length and not welded on the are bolted which is weaker. If you weld your stockers you might a see a little increase but a welded set of full lengths would be the best.
Old Dec 12, 2009 | 07:23 PM
BraMas's Avatar
BraMas
The bolted ones work but will still flex a little. If your going to do it you are better off doing it right and having Full Length Connectors welded in.
Old Dec 12, 2009 | 07:32 PM
mustangmancp
mkay ill have to look into those
Old Dec 12, 2009 | 08:33 PM
livefast1's Avatar
livefast1
welding factory connectors in is a waste of time and recyclable steel. verts need connectors more than hardtops......... if you don't believe me put one on a post lift and watch the door/quarter panel gap grow.
Old Dec 13, 2009 | 03:01 PM
teej281's Avatar
teej281
4.6L Section Moderator
Verts do need subframe connectors. MM are probably some of the best ones. Im going with those hopefully soon. And bolt-on ones are a waste. I mean verts come with stockers but they suck something awful. So you need to get new ones that are full length and welded in.
