Another cam thread
Old Dec 21, 2009 | 11:20 AM
  #41
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
.005" is what you said you measured for the clearance on the CMS Stage 2 N/A cam, right? And have you measured the Hitech Stage 2 N/A cams? I want to say you did in one of the threads you linked and you said they were a dead hit at 110 IC.
Old Dec 21, 2009 | 12:25 PM
  #42
nickmckinney's Avatar
nickmckinney
I have measured both them and the Comp 270 which uses the same intake lobe. Here is a thread from someone that had the Hitech hit at 110 and had to retard them to clear, also describes the tapping noise quite well:
http://www.modularrevolution.com/for...t=11436&page=3
Old Dec 21, 2009 | 04:40 PM
  #43
WannaBeGearHead
Go Texas!!!
So that is why Hitech Stage 2 n/a cams are 111 and not 110 anymore. To bad the guy in that thread didn't measure his PTV clearance at 112.5. If 110 was a dead hit, how much more clearance would a person get with just retarding it 1*?
Old Dec 21, 2009 | 04:44 PM
  #44
nickmckinney
Hitech are 112 intake centerline, they have always had the same 111LSA. They retarded the cam a total of 2 degrees somewhere along the way which would give about 0.030" more clearance. To understand the old and new specs:
111LSA advanced one degree gives 110 intake centerline and 112 exhaust centerline (original spec).
111LSA retarded one degree gives 112 intake centerline and 110 exhaust centerline (new spec)
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
