Racing
Old Dec 21, 2009 | 12:37 AM
Bman2000's Avatar
Bman2000
Originally Posted by Xemeth
Nope. It depends on the suspension, weight, weight transfer, and traction. They actually have competitions with wheel stands to see how long the cars will hold it. They set their suspension up specifically for it. Lifting the wheels like that is terrible for drag racing if you're really concerned about the fastest possible times, though.
Its only bad if you lift them way off the ground, you can pull a front wheel and im sure that doesnt kill your time, but if you do lift the car more than a few inches im sure it has a much larger affect, that and you wont be able to steer lol.
Old Dec 21, 2009 | 12:46 AM
945LSTANG's Avatar
945LSTANG
Originally Posted by Bman2000
dont forget high launch rpm is usually involved
+ nasty traction.
Old Dec 21, 2009 | 11:01 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Kinda already mentioned but suspension, traction, also some guys lighten up the front end by removing the ac, power steering, using a tubular k member, skinnies, one piece front or at least a modified front end such as removing the impact bar and absorber. just depends on the class and such.
Old Dec 21, 2009 | 11:11 AM
dimebag's Avatar
dimebag
It can be done w stock power. And some suspension wrk and drag radials. I've done it myself
Old Dec 21, 2009 | 12:21 PM
lilcrate's Avatar
lilcrate
slicks and skinnes...traction in the rear, light weight in the front.
Old Dec 21, 2009 | 05:39 PM
mustangmancp's Avatar
mustangmancp
I think these guys have covered it. If you look at JayC's sig you can see him almost liftin the wheels off the ground.
Old Dec 21, 2009 | 08:37 PM
SVTeeshirt's Avatar
SVTeeshirt
i've seen it.
Old Dec 21, 2009 | 10:53 PM
JayC's Avatar
JayC
[QUOTE=mustangmancp;6705714]I think these guys have covered it. If you look at JayC's sig you can see him almost liftin the wheels off the ground.[ /QUOTE]
There's a little daylight there but not much. After I got my suspension tuned properly my car launches "out" not "up".
Old Dec 21, 2009 | 11:04 PM
StriderTacticaL's Avatar
StriderTacticaL
Hey JayC what size rims and tires are you running on the back from your sig?
Old Dec 22, 2009 | 05:47 PM
JayC's Avatar
JayC
15x8 Telstars with 26x11.5 Hoosier Quick time Pros
