So i opened my diff up the other day...
#21
too much bad info in the thread. The rev limiter is what you should be worried about and should be around 6000rpm, my was 6050rpm stock to be exact. 4.10's in a 5 speed will put you right around the rev limiter (not 6300) at 110mph on a stock height tire which I've never heard of a 275/35-17 (maybe a 275/40-17) but if it does exist it would be shorter than stock which is a 245/45-17. mustang_pa I sure hope you have a built motor if you're really spinning that thing to 6700.
I live in cape may.
#22
#23
correction my rev limiter does say around 5700rpmish. My nitto's are 275/40/17's. I watched one of my video at the track and i am shifting at 6200-6300. I have full bolts almost full suspension w/ spec stage 2 clutch and aluminum fly, no built engine. I got it tuned at radical racing and he said i could shift passed red line 3 or 400 rpms.
I live in cape may.
I live in cape may.
#24
With 4.10's and a stock height tire, I trapped 114 @ roughly 6100 rpm. If you need more room than that, mph wise, get some 27" et street radials(255/60/15). That is what I have and I have trapped 118 mph @ roughly 6100 rpm.
#25
if you rev limiter comes in at 5700 then either your tach is off or your tuner tuned your car to have a revlimit below the factory 6000-6050 limit, which wouldn't make sence. What also doesn't make, unless one of us is misunderstanding something is if you rev limit is in fact set to ~5700 you would not be able to shift at 6200-6300. You rev limit does just that, limits the amount the car car will rev. Anyways at your power level you do not need 28" tall tires.
My whole idea with going w/ 3:73's was to bring the rpms down and out of red line or just at red line when going though the trap. That way if i do a built engine i can get more power out of it and that would raise my speed and rpms when i go though the traps without having to shift into 5th gear at the very last 50ft.
At 110mph my tach is saying around 6100rpm's right now. I just wanted to bring that down to 56-5700rpm and 3:73's would do that for me @110mph and give me some room for (220ish) an extra 10mph @ 6k rpm when i get the power later on. That's how i am thinking for this.
#26
I think we are just misunderstanding eachother. I don't know what my rev limiter is set at (i can check when i get the car today w/ my diablo tuner). I haven't hit the limiter when shifting at all, last time i have ever hit it is before i bought a tuner and raise it a couple hundred rpms above red line cuz i would hit it all the time.
#27
#28
I personally don't think that shifting that high of rpm yields the best results. I have gone much quicker and faster by reducing my shift rpm by 2-300 every shift. For example, I try to shift into 2nd ~6000, into 3rd ~5800, and into 4th ~5600. When I started doing that my et's went down and my mph went up. Both on motor and on the hose.
Your rear gearing may effect the actual rpm that works best for your car. But for a bolt on 2v, sc and nitrous included, I think this method works best. Once you have headwork and/or cams that will change things a bit.
09-25-2015 09:06 AM
