Update on cam install...
Old Jan 1, 2010 | 10:15 PM
02stang2113's Avatar
02stang2113
Originally Posted by 01MGGT
Nope no springs. Without doing those it was like 2 hours or so taking my sweet time on the first cam and then the second was like 35-45 minutes
WOW, Thats some pretty damn good timing... too bad u broke something. lol
But good luck!
Old Jan 2, 2010 | 12:32 AM
mrtstang's Avatar
mrtstang
Kept the cam gears from my PI springs. I bought new bolts at the dealership for them but the CMS cam has a bigger bolt it uses so I couldn't use the new dealership ones. Waste of 20 bucks
Did you degree those cams??? If so, what kind of clearence did you have?
Old Jan 2, 2010 | 01:24 AM
01MGGT's Avatar
01MGGT
Nope CMS said it wouldn't be needed unless I wanted extra insurance. We slowly rotated to motor several times to check for any interference. Eerything feels and sounds smooth as stock. Getting the followers back on was a little more tricky with the difference in the lobes on the cms cams vs. the stockers but once we figured out the trick they popped in like butter. Now just got to figure out how to take off the front cover without removing unneeded crap.
Old Jan 2, 2010 | 01:47 AM
02 Silver GT's Avatar
02 Silver GT
Ya taking the front cover off is fun indeed not horrible tho....
Old Jan 2, 2010 | 01:52 AM
01MGGT's Avatar
01MGGT
Don't think it's going to be to bad. Some people say remove the cooling fan and all that crap and others say to remove half the amount of stuff. Guess I will figure it out. Do you guys think I can remove the driver side chain guide WITHOUT removing the timing chain? In pictures it looks like two bolts hold it and then it should slide out from behind there and has small clips on the bottom where it hooks on the motor....
Old Jan 2, 2010 | 01:17 PM
02 Silver GT
No it is not necessary to take off the cooling fan and yes you can remove it without taking off the chain there are 2 small bolts that hold it on and a pin that comes out of the block that slides in a hole on the guide if i remember right but y not just go ahead and reset up the timing just to make sure it is right on or degree them if you have the equipment and the time (i wish i would have because im missing around 20 rwhp after my cam install/tune and have no clue where it is....lol)
Old Jan 3, 2010 | 02:58 AM
01MGGT's Avatar
01MGGT
Timing cover and everything is off. Just waiting on parts!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
