misfire cylinder 6
Old Jan 16, 2010 | 11:31 AM
bedaloca's Avatar
bedaloca
Default misfire cylinder 6
I have a 06 mustang GT I keep getting a cylinder 6 misfire. I replaced all 8 spark plugs and no change. Performed a relative compression test several time cold all cylinders passed at 100% compression. Back probed cyl 6 injector and coil circuits at the pcm. The test light was flashing bright and consistent while miss was occurring. Also preformed engine running compression test on cyl 6 found compression at 75 psi running and would intermittently drop 25 psi... What can I do to fix this problem?
Old Jan 17, 2010 | 07:58 AM
01MGGT's Avatar
01MGGT
Even with all the info you gave I am a little to inexperienced to be of much help. But here is a free bump to help out and welcome to MF.com!
Old Jan 17, 2010 | 03:57 PM
bedaloca's Avatar
bedaloca
thanks appreciate it
GimpyHSHS
19
Dec 19, 2023 01:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
