Cam install done!
Old Jan 17, 2010 | 01:38 PM
JC316's Avatar
JC316
Originally Posted by 01MGGT
Okay, just tried to start the car and it won't start. I can't see anything at all left loose or anything. The first two times it sounded like it was running and then died almost right after. Now it just keeps cranking and won't ever start. I have my tune in sniper as the a 91 octane but I left all the timing at stock till I got it running. The idle speed is set at 150 over stock. And I selected the 90mm MAF and 42lb injectors. Any ideas?!?!?a
EDIT. Shouldn't the car still start with the front end up on jack stands?
Yeah, it will start with the front end up. Double check that you hooked the crankshaft position sensor and camshaft position sensors back up. Did you make sure to install the crankshaft position wheel correctly? It has a front and back.
Old Jan 17, 2010 | 01:44 PM
01MGGT's Avatar
01MGGT
Both are connected. I am pretty much 100% sure. I am pretty sure I hear the fuel pump when I turn on the key as well. The button thing in the trunk feels all the way in. Is this the correct position?
Old Jan 17, 2010 | 01:53 PM
01MGGT's Avatar
01MGGT
Do I need to reset the computer by un hooking the battery once the tune has been flashed?
Old Jan 17, 2010 | 02:13 PM
JC316's Avatar
JC316
Ok, what about the wheel? It's the one that goes on the inside of the timing cover, in front of the timing gears. If you installed that backwards, it could be causing your symptoms.
Old Jan 17, 2010 | 02:34 PM
01MGGT's Avatar
01MGGT
Got the car running Got a cel so downloading it with sniper now to see what the deal is... be back with some results
Old Jan 17, 2010 | 02:36 PM
01MGGT's Avatar
01MGGT
P0353 ignition coil C Primary/Secondary circuit. I did see a tad of smoke after shutdown coming from one of the spark plug wells. Any ideas?
Old Jan 17, 2010 | 02:47 PM
JC316's Avatar
JC316
Which spark plug well? Did you tighten all of the plugs down properly?
Old Jan 17, 2010 | 03:00 PM
01MGGT's Avatar
01MGGT
I took the one that had smke in the well and replaced the boot and spring with a new on I had left from last time one got torn. Now just trying to get the damn thing to idle right. AFR will sit at about 14.5 but can spike to 18 if you give it to much gas to keep it running.
__________________ It's the second well from the front on driver side. Can't remember the cylinder number.
Old Jan 17, 2010 | 03:02 PM
01MGGT's Avatar
01MGGT
now I just got a po357 and a po353. Does it matter wich side the coils go on? I noticed that one set of 4 had one part number that was ending in an even number I think the the others were odd number. I put all evens on one side and all odds on the other. The ones with the ending number of 3 I think it is are on the driver side.
Old Jan 17, 2010 | 03:16 PM
Synyster06Gates's Avatar
Synyster06Gates
According to this site, the firing order is...
http://www.miracerros.com/mustang/pipes_hpipe.htm
4 8
3 7
2 6
1 5
Maybe the GT's wires are different, but mine all had the number placed on the wire somewhere to make sure you don't confuse them
EDIT: Misunderstood the question. I dont really think that should make a difference if it's all getting spark, ect?
