Cam install done!
Old Jan 17, 2010 | 03:30 PM
  #21
01MGGT's Avatar
01MGGT
So far no mroe cel but still having to keep my foot a bit on the gas to stay running. If not it just tries to die. Idle speed in sniper is set at 250rpm over stock. I had done the IAC mod a while back but I took IAC off and switched gasket around to the biggest hole in the gasket. Any ideas?
Old Jan 17, 2010 | 04:38 PM
  #22
01MGGT's Avatar
01MGGT
Got the guys on the Sniper forums looking over my tune now. Said I should have no problem with the injectors and MAF. Where is cliffy when you need him
Old Jan 17, 2010 | 05:39 PM
  #23
01MGGT's Avatar
01MGGT
We finally got it to idle with stock MAF and the 42#ers. Still working on it it right now then I will try and get a video up after I reinstall Imovie
Old Jan 17, 2010 | 05:59 PM
  #24
StriderTacticaL's Avatar
StriderTacticaL
Hey glad to hear you got it running. I got a question, are you tuning for your new cams with just the Sniper SF package? I only ask because I might be getting cams sometime and I want to know if my software will be sufficient to tune for it
Old Jan 17, 2010 | 06:05 PM
  #25
01MGGT's Avatar
01MGGT
Yeah trying to anyways lol. Now it's back to not wanting to idle. On of the Sniper guys is looking into my logs. Was saying bank 2 short term fuel trims were way rich or something. I am a noob at this
Old Jan 17, 2010 | 06:10 PM
  #26
mrtstang's Avatar
mrtstang
Besides the obvious problems, how does it sound...when it does idle lol?
Old Jan 17, 2010 | 06:19 PM
  #27
StriderTacticaL
Do you have some kind of datalogging software? or are you using the Recon thing?
Old Jan 17, 2010 | 06:24 PM
  #28
01MGGT's Avatar
01MGGT
Sounds great when it will idle lol. I am using recon. All I got heh
Old Jan 17, 2010 | 07:17 PM
  #29
01MGGT's Avatar
01MGGT
Just an update. We did some adjsuting on the throttle stop to raise tps voltage to about 96 at closed throttle and she is running at idle right now. Still have to give it some gas to start but we will see where he takes me next
Old Jan 17, 2010 | 07:53 PM
  #30
01MGGT's Avatar
01MGGT
still doing some tweaking but it starts and idles. It's dark as **** here and -13*f outside so the vid will come tmrw but will keep you posted as we progress!
