Best gas saving mods
Old Jan 25, 2010 | 09:08 AM
1999mustang2000's Avatar
1999mustang2000
Default Best gas saving mods
What are some good mods or tips to help with get mpg. My mustang seems like the biggest f'n gas hog. I swear i can drive and watch the gas hand move lol.
Old Jan 25, 2010 | 09:32 AM
Eagle2000GT's Avatar
Eagle2000GT
I"m confused. According to your garage you installed 4.10 gears. Why did you put in 4.10s if gas mileage was an issue?
But if gas mileage is important there are techniques to use to improve it but you have to drive like your grandmother in order to do them.
1. Be very easy on the throttle. Throttle movement uses gas.
2. Keep rpms below 2000. Rpms use gas.
3. Coast up to lights and stops signs with a nice easy stop barely using your brakes.
4. Attempt to keep a nice constant speed. This usually involve driving below the speed limit so that you do not rush up on traffic and have to use your brakes.
5. If you are driving in hills, let the car speed up going down hill and slow down going up hill. This is the exact opposite that cruise control does.
There are other techniques but since I don't follow any of them I can't remember what they are. My favorite driving technique is throttle to the floor with rubber burning results.
Old Jan 25, 2010 | 09:33 AM
stangalator's Avatar
stangalator
there are mods you can do to get it down. Make sure your AFR is correct for idle/cruse, running around rich under those conditions can kill mileage. I believe anything that improves volumetric efficiency (VE) closer to 100% will help mileage. Those are all bolts on basically, your intake, exhaust, UDP maybe, etc (minus cams and gears for the most part). Having the correct TB helps to, under low loads if you have a 78mm set up the velocity charge will be very low and not atomize the fuel as well.
The velocity charge is like momentum of a wheel, because if you dont change the intake port the same air velocity would go through it at steady state (flow rate the same assuming no leaks)
Biggest one people will say is the gas pedal mod, baby it and itll return the favor (in mileage, not fun, haha)
Hope that helped
Old Jan 25, 2010 | 09:37 AM
1999mustang2000
gas mileage isnt a issue i was just wondering a few ways to improve it some, i needa put a block of wood under the happy pedal
Old Jan 25, 2010 | 10:06 AM
iMTB's Avatar
iMTB
My gas mileage tune from VMP makes a big difference actually. I always drive with that on now.
Old Jan 25, 2010 | 10:42 AM
02TrueBlueGT's Avatar
02TrueBlueGT
Didn't you install the converter? That kills it as well. Looking at about another 1-2 mpg decrease from that, maybe more.
Old Jan 25, 2010 | 11:14 AM
w8less's Avatar
w8less
buy a honda?
Old Jan 25, 2010 | 11:24 AM
Eagle2000GT
Originally Posted by fs308
buy a honda?
Or a Harley. I get 38 mpg on mine.
Old Jan 25, 2010 | 11:28 AM
boduke0220's Avatar
boduke0220
a kia would help lol
edit..you beat me to it
Old Jan 25, 2010 | 11:38 AM
02stang2113's Avatar
02stang2113
Sell the mustang... or drive it like an old person
