New plan?
Old Jan 31, 2010 | 02:09 PM
teej281's Avatar
teej281
4.6L Section Moderator
you should ask dad for a new longblock if he's willing to help fund the project. lol
Old Jan 31, 2010 | 04:51 PM
RyanK's Avatar
RyanK
The thing Is I want to keep it a 4.6 and make it interesting So I think i should start with Slicks,skinnies/suspension what do yall recomend for suspension?
Old Jan 31, 2010 | 10:27 PM
teej281's Avatar
teej281
For strictly quarter mile use, tubular front suspension, coilovers on all 4 corners, MM extreme duty lower control arms, some nice adjustable upper control arms with sperical rod ends on all sides. Then i would start looking into the built rear and then the slicks and skinnies just because you need to be able to handle the power before you make it. Things will be a lot easier that way. Also, new tranny will be needed more than likely with the abuse it will be taking. Or just go to a junk yard and find as many t45's as you can and just use a bunch of stock ones for a while. Then when one breaks just take it out and put another one in.
Old Jan 31, 2010 | 11:40 PM
RyanK's Avatar
RyanK
with what you just listed where would i be at 1/4 mile time?
Old Feb 1, 2010 | 07:34 AM
teej281's Avatar
teej281
Well with that suspension setup, you'll be good for the power that you could ever make with your car pretty much. That is almost the same setup that Ox was using with 665rwhp and that was working well for him i'd say. Also look into some adjustable struts to go with the rest i mentioned. I dont know how much you would benefit right away from all this suspension because youre not making quite the power to need it all, but why do it multiple times? Do it once and get it over with. In the case of how fast you'll go down the 1/4, your limiting factor will no longer be hooking. Your new limiting factor is the power. You'll be able to use every bit of the power that youre making right now, but you'll want to add more power to take full advantage of the suspension. You'd probably be sitting at a strong mid 13 without a PI upgrade with full suspension and slicks/skinnies. Anyone else???
Old Feb 1, 2010 | 01:23 PM
Z28KLR's Avatar
Z28KLR
Yeah, mid 13's with a stock NPI motor, full suspension, and weight reduction sounds reasonable. Full suspension, along with slicks and skinnies should be worth at least 0.5 sec., and the rule of thumb I've always heard about weight reduction is that each 100lbs. is worth 0.1 sec.
Old Feb 1, 2010 | 01:54 PM
RyanK's Avatar
RyanK
so then what should i just spray?
Old Feb 1, 2010 | 02:10 PM
Z28KLR's Avatar
Z28KLR
100 shot with a good tune should be pretty safe, and should get you into the mid/high 12's no prob with the mods mentioned above. Might even be able to do a 125 shot without breaking anything for a while. And I could be wrong, but I think anything more than 100/125 is just asking for trouble on a stock sb.
Old Feb 1, 2010 | 04:49 PM
teej281's Avatar
teej281
well with a stock npi longblock, he should be good to about 400rwhp. So that means that he could spray probably about 125 or even 150 shot and still be fine. I'd limit it to a 125 shot though. But i'd suggest a ported PI head/aftermarket cam combination with the stock pi manifold and then if thats not enough, spray it with like a 75 shot.
mrtrodonet
Sep 19, 2020 03:12 PM
alan0614
Carolina Regional Chapter
38
Nov 30, 2015 09:24 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
wraith777
Sep 28, 2015 10:49 AM
