Eibach front/sway bars OR MM Panhard bar
Having a tough time deciding which mod I want to start out with..
-Eibach Front & Rear sway bars
http://www.americanmuscle.com/eibach...4-mustang.html
OR
-Maximum Motorsports Panhard Bar
http://www.latemodelrestoration.com/...Natural-Finish
The price is virtually the same. Just need help figuring out which one would help corner better.
Thanks
OR
Thanks
02Black... if you want to go PHB you really need to go TA as well to do this correctly. MM recommends you remove the drivers UCA in lue of the TA installation. This is commonly referred to as the "poor man's tri-link" and don't see a whole lot of improvement over your current situation.
As for rear sway bar, this is a tuning device and would either not get one until you are completely done with ALL suspension mods, or go MMRSB (need to choose a number, so can PM me if you have questions) so it can be adjusted for understeer/oversteer issues.
Jazzer
Jazzer
OR
Thanks
OR
Thanks
1. Full Length subframe connectors
2. Lower control arms
3. New shocks and struts
4. Decision on spring style for your car (stock style or coilovers)
Then you want to start doing stuff like your panhard bar/watts link and torque arm. I mean if youre doing this just for the street, i dont know if i'd go past the stuff listed in the list. Maybe a STB or sway bar but other than that, thats it. Now im starting to get into auto-x and maybe some open track so im going further than the list. But good luck. Let us know the list and what youre planning on doing and we'll help as much as possible. Jazzer helped me IMMENSELY!!!
-Kyb shocks/struts
-Eibach Sportline springs front/rear
This is just a street car; I go to the track every once in a while. I mostly just want to get rid of that body roll, and make it handle faster around windey roads. I take a 15min windey road drive to my house everyday and always try and push my car to its limits..
First off, i'd get something a little bit better than KYB's for dampers and get some more performance oriented springs. As MM states on their website, for handling they recommend nothing lower than a 700lb stock style spring for handling on the front and the sportlines are only in at 640lb at the extent of their progressiveness. So some stiffer springs like H&R SuperSport or Race springs that have the proper spring rates for performance handling might be something to look into, just because i know how Eibach springs are more visual than performance oriented. But first things first, get some subframe connectors and get some lower control arms before you do anything else. Then come back to us if you want even more performance.
