Cat back hp/torq gains?
I've got a Magnaflow True X-Pipe w/ high flow cats and Flowmaster 3 chamber mufflers welded on the stock pipes. I'm wondering if there will be any diference in power if I get the larger cat back pipes (I believe 2.5'') to replace the stock ones. Intake mods in sig.
all aftermarket ones are going to be the same....all mostly 2.5" mandrel bent
only diff comes from mufflers and the sound they put out. the hp difference b/w a slp straight through and say your flows (chambered) will be minimal
so on a pretty much stock car like yours just go with a catback that you like the sound of.
you wont see hp gains or loss unless you are pushing good amount of hp out of the engine.
Well a 3 chamber flowmaster vs. an SLP muffler will result in a more than typical gain because 3 chambers...thats pretty restrictive. But nothing is really gonna be noticeable. The 2.5" piping will make the sound hollower. And stainless steel and aluminized steel both sound different. Just throwing that out there. But do catback based off of sound...not power.
