failed helicoil
Old Feb 6, 2010 | 06:02 PM
amusgrove81's Avatar
amusgrove81
Default failed helicoil
Anyone here know what to use on a failed helicoil on a blown sparkplug?
Old Feb 6, 2010 | 07:16 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
TIME-SERT (which should have been used in the first place) has a "BIG-SERT"kit made especially for heads that were mangled by Helicoils.
They also have a triple oversized kit they call the "...last chance repair for Ford 4.6/5.4 heads."
Helicoils suck for any "impact" load sort of application...
Old Feb 6, 2010 | 09:27 PM
amusgrove81
can i use this with the head still on
Old Feb 6, 2010 | 09:53 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
You can, with the usual precautions (grease the drill and tap, vacuum/blow the cylinder out when done)--but...
The kit is $300 (Amazon), the inserts are $6 to $8 each last I knew--makes a 1/4" drive torque wrench seem pretty cheap...
Old Feb 6, 2010 | 10:20 PM
amusgrove81
$300 it might be easier and cheaper to bring it to a machine shop
Old Feb 6, 2010 | 10:38 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Perhaps, make sure they use a BIG-SERT and don't bugger up some other "solution"--BIG-SERT is the only proven fix when a Helicoil has gone bad...
Old Feb 6, 2010 | 11:10 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
or use this as an excuse to buy some trickflow heads
Old Feb 8, 2010 | 08:28 AM
DR.DIESEL's Avatar
DR.DIESEL
i just order a kit that does the repair for previosly repaired heads.its made by cal-van.im starting to see a few vehicles that have already had the heads repaired and there blowing out.not common but is happening.they say the kit i bought is a fix that will last.well find out.i paid 245$ for it.
Old Feb 8, 2010 | 12:46 PM
nickmckinney's Avatar
nickmckinney
I have seen every kit out there and just dropped another $500 order at Timesert. They are the only ones other than LocknStitch that I have never seen come back out. I have 6 sets of race heads here getting all 8 chambers done (I go through a ton of inserts).
jwog666
Dec 27, 2021 08:09 PM
GLOCKer
Sep 28, 2015 07:36 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mltdwn12
Sep 23, 2015 08:54 AM
TfcCDR
Sep 14, 2015 12:08 PM
