need help with spring isolators
Old Feb 11, 2010 | 02:51 PM
quickndslick2's Avatar
quickndslick2
Banned
Question need help with spring isolators
i have read on hear about ppl removing there isolator for more of a lowerd looked, does this actually work?? if so what ARE the spring isolators (what do they look like) or where are they located?? and how can i remove them??
Old Feb 11, 2010 | 03:18 PM
massmustang02's Avatar
massmustang02
Spring isolators are the rubber pieces that sit on top and the bottom of springs. They're designed to stop the metal spring from rubbing on the metal spring perch. Yes people remove these to give their cars a little more drop. There is no harm to removing them.
The spring on the left has an isolator on the top it...
Old Feb 11, 2010 | 03:29 PM
quickndslick2
Banned
ohh ok perfect thanks alot man
Old Feb 11, 2010 | 04:38 PM
hpwrestler220's Avatar
hpwrestler220
You should see anywhere from .25"-.75" of a drop.
Old Feb 11, 2010 | 05:03 PM
teej281's Avatar
teej281
4.6L Section Moderator
Note that there may be more road noise after taking the iso's out because of metal on metal contact of the spring and the spring perch. Just a warning.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
