Sputtering through gears
It is unlikely to be the TPS. However it's quite likely it's the plugs and/or COP boots, and not as likely to be the COPs.
The OEM COPs are rather robust and do not fail anywhere near as often as they get changed out. In fact Ford has a TSB (#03-14-4) asking dealers to not change COPs just for the sake of changing them--it turns out that 50% of the COPs returned to Ford from dealer's warranty work had nothing wrong with them...
I think what Cliffy was getting after was that you should pull the COP's, one at a time, and inspect the boots for any signs of damage before you get crazy with spending money on new parts. And as somebody else mentioned, while you have your COP's off it may be worthwhile to check your plugs. The TPS is on the front facing side of the plenum (little black box w/ 2 screws fixing it to the plenum), directly across from the throttle cable linkage on the rear facing side if you really want to check it (which can be done with a multimeter on resistance setting). There's a way to check your COP's in terms of measuring resistance, too, between the primary and secondary coils; pretty sure there's a sticky around here somewhere for how to do it and what to look for. Another thing you could do, is if your tuner has datalogging feature you could plug it in and go for a drive and see if it tells you anything (like misfire @cyl#x, etc.), might help you narrow it down some. Also note that most of the things you're suspicious of (bad TPS and COP's) are usually accompanied by a CEL if the problem has been persistent for at least the last 5 drive cycles. In my experience with bad TPS', the throttle was jumpy within a certain moving range of the throttle, not any particular rpm range; nor was it dependent on load or lack of to the engine.
check the connection on you Fuel Pump Driver Module (fpdm) i had a random hole in my driver side rear fender well. on we days it would throw water on the connection and screw with the car. its located behind the carpet in the trunk on drivers side.
just something to look into. after that i would look at spark plugs if they havent been touched.
Well in my case, i was 100% sure it was my COP's since i replaced mine with my friends in his GT and the car ran fine with his on my car..
In your case, i would consider pulling the plugs and possibly even changing them. If that didn't work, maybe check your air filter to see if there is water in it. Otherwise, it's probably the COP's. If it's the COP's, you can buy STOCK REPLACEMENTS LIFETIME WARRANTY for $90 shipped... Just look at that sticky about them that devongarver or w/e his name is posted up...
Please, I mean no offense--however what you need to to is stop whining, complaining, asking the same questions over and over, and waiting for some "magic bullet" to pop up. Then start checking some of the possible causes the good people trying to help you have put forth.
Just pick any one of the suggestions and start taking action...
FWIW, if it was me I'd check for dampness around the FPDM (just to be sure, and because that shouldn't take more the 2-3 minutes), then I'd change the spark plugs and check the COP boots while doing so.
The COPs can be given a field check by measuring the resistance of the primary and secondary windings (here's a link to the COP sticky).
KingRando
Oct 2, 2015 08:06 AM
junior04
Sep 28, 2015 10:53 AM
1998, 2001, datalogging, engine, ford, gear, gears, gt, hestitating, misfire, mustang, sputtering, xcal, zx6r
