Just finished up the Vortech
#42
Thats awesome bud! Congrats! I guess N/A CMS cams work just fine with the blower huh?! Can you post all your mods? I think we pretty much have identical setups with maybe a couple different brands lol. I can't believe you made those kind of numbers! I would hope that I would be able to hit 400 with my 5speed and a killer tune but I don't know, yours seems gifted lol. Now go make some videos of acceleration!
#43
Ok here's a full mod list....
Vortech V1 S-Trim(3k on it)
3.60 pulley
Diablosport MAFia Extender
Cushman MotorSports Stage 1 Cams
70mm Professional Products throttle body
Professional Products Intake Plenum
MAC Off-Road X-Pipe
Magnaflow Magnapack Catback
4.10 Gear
SVT Focus Fuel Pump
FRPP 42lb Injectors
NGK TR6 plugs(.032 gap)
K&N Air Filter
And a Tune
I gained 128HP and 82TQ from the blower woot!
I'll post up some more vids when I get around to it
3.60 pulley
MAC Off-Road X-Pipe
4.10 Gear
SVT Focus Fuel Pump
FRPP 42lb Injectors
K&N Air Filter
And a Tune
#45
You also have cms stage 1 na cams right? I so can't wait. To bad there is no dyno here so I'll have to use the butt dyno how are the 4.10s workng outnow? I still haven't decidedon a gear yet. What was the duty cycle on the fuel pump? I'm affraid my focus pump will be maxed after seeing your numbers. I may get with you to see what timing and stuff u used since there isn't a dyno tuner in Alaska and I'll have to dial mine all in manually with the sniper software.
What is the mafia extender? Maf? I'll be using a lightning 90 mm and hopefully it won't peg. Already got 42# injectors. Can't wait to see more bids and see how bad traction is with those gears lol. I am girding u are running 93 octane but I'll be limited to 90 octane and meth prob won't help me since I can't dyno tune.
#46
I got my pump from Kurgan Motorsports
I'm not sure on the duty cycle of the pump.
The MAFia extender is this thing here...
http://www.vmptuning.com/store/image...ucts/mafia.jpg
it plugs in between the MAF and the wire going to the MAF to broaden the range
Yes, I'm running 93 octane.
And yes traction is DEF an issue now, if my roomate would buy my tires now I could get some drag radials which would help out a little im sure
09-16-2015 07:53 PM
