imrc delete question
Old Apr 5, 2010 | 10:14 PM
1999mustang2000's Avatar
1999mustang2000
Default imrc delete question
what if i just take out all the butterflys and the electronic **** and cables and just left it completely open? what could it hurt? wouldnt it just allow more air to the heads and wouldnt that be a good thing?
Old Apr 5, 2010 | 10:50 PM
BraMas's Avatar
BraMas
That is exactly what you do when you delete the IMRC's in an b head 4v. But you have to fill the holes that the shaft for the butterflies used. Does it help to delete them? Yes! but it also kills your low end torque. The problem is the engine is getting to much air in lower rpm's that is why they stay closed until 3250 rpm's
Old Apr 5, 2010 | 10:56 PM
boduke0220's Avatar
boduke0220
you will need a dyno tune i think
Old Apr 6, 2010 | 10:12 AM
BraMas's Avatar
BraMas
you will be fine with a e-mail tune. They just have to adjust the fuel tabels a bit and turn off the IMRC's so you dont gete a CEL
Old Apr 6, 2010 | 12:39 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Am I missing something, there are no IRMCs on the 2V engine?
However if there were you would lose low-end torque by removing them--what they do is improve charge velocity at lower air flows, benefitting emissions and power under those conditions.
Old Apr 6, 2010 | 02:49 PM
boduke0220's Avatar
boduke0220
he got a mark viii motor because his 2v spun a bearing
Old Apr 6, 2010 | 02:58 PM
JC316's Avatar
JC316
So long as you are using the GT computer, then it won't fire a code for the IMRC's. Yeah, you lose some low end torque, but if you have gears and a stick shift, then it's not noticeable.
Old Apr 6, 2010 | 03:08 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
That makes sense! I could tell that he knew what they were and did, so figured I was missing something.
I would not disable the IMRCs on a street car, you can tune around some of the low-end loss but you can't get the charge velocity back...
Old Apr 6, 2010 | 08:48 PM
1999mustang2000
yep hes right i have a mark viii motor, i do not wanna mess with keeping them because the little control box and the cables were broke when i got the motor, so what if i just jb weld the butterflys?
Old Apr 7, 2010 | 10:43 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
You can buy delete plates still....
When I had my 98 cobra I was about to buy IMRC deletes and custom short runner intake. Guys were seeing pretty big power gains (after a tune)
GimpyHSHS
Sep 18, 2015 12:27 PM
Mr. D
Sep 17, 2015 08:17 AM
BrantleyS550
Sep 14, 2015 04:18 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Camster
Sep 10, 2015 11:18 AM
