IAC gasket reusable?
I think you mean RTV (Room Temperature Vulcanizing)...
If the gasket is in good shape, no tears or deterioration, then I'd use it--without the RTV sealant. Just make sure you wiggle things a bit when making up the fit so that the gasket ends up in more or less the same position as originally installed. I've had mine on/off 3 or 4 times with the original gasket.
If you do use RTV make sure you get a "Sensor Safe" flavour--some contain chemicals that will foul the O2 sensors--it will be clearly marked as such...
Ford says quite distinctly in the shop manual "Note: The IAC Valve Assembly is NOT ADJUSTABLE and CANNOT BE CLEANED."--that has been my experience, further reinforced after I cut one apart.
They are specifically (and well) designed so as to not stick, so cleaning is at best a temporary fix...
Yup, that's why the engine can run to some extent with a bad IAC--if the IAC were removed and the ports (in the plenum and intake tube) left open the air-fuel mix would be so lean as to likely not even ignite.
If the ports were blocked there would be insufficent air being bled past the TB to sustain idle...
