Camber specs on a 98GT
Old Apr 26, 2010 | 09:32 PM
jheugatter's Avatar
jheugatter
Default Camber specs on a 98GT
Ok guys, so I've already read this in another thread but can't locate it right now. Does anyone know what the camber specs on a 98gt with Eibach Sportlines and Tokico struts should be? I've got to much negative camber goin on.
Thanks.
Old Apr 27, 2010 | 10:32 AM
tdcalhoun89's Avatar
tdcalhoun89
I have no clue, but I'm about to install some MM c/c plates to correct my crazy negative camber. I'm going to take it to my mechanic to have it professionally aligned after I install them though. Check Jazzer's suspension guide in the stickies, it might have some helpful info in there.
Old Apr 27, 2010 | 12:06 PM
Stevecooper's Avatar
Stevecooper
Google is your Friend, Cliffy has posted the stock specs here. That being said you may not want stock depending on the application. I run over 3 degrees of negative camber at the track.
http://www.moddedmustangs.com/forums...ent-specs.html
Old Apr 27, 2010 | 06:43 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I am running -1.5° camber on the street, it chews up the inside of the tires a bit however the improved handling (much less tire roll-under and plowing in turns) makes it worth it.
It's just a bit below the edge of instability at highway speeds, but not so close that there is any real problem--lane changing with someone riding shotgun is a gas, they think we're going to die!
vargas
Jun 17, 2017 12:17 PM
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
