quick! what size is this?
Old May 7, 2010 | 12:10 PM
MustangMan00's Avatar
MustangMan00
it goes on that bottom part, where that electrical connection is
Old May 7, 2010 | 04:36 PM
nascrchi's Avatar
nascrchi
Originally Posted by 0949er
I was originally going to do a "T" setup because I Was told that that "cap" was a pain in the *** to get off. However, I realized while tring to maneuver the T fitting into place to get everything hooked up that there was not enough clearance between the t fitting and some of the pipes going to the water pump. So I decided to say f-it and tried to remove the cap anyways. To my surprise, the cap came off extremely easy, so I moved the EOT sensor there and placed the oil gauge where the EOT sensor was...
I tell you what that first start up is scary when you pray you don't have any leaks in that line... especially inside the car, lol!
I know they are kinda crooked, they aren't fully pressed in yet because my boost gauge isnt hooked up yet... I am waiting to finish that so I can set them both perfectly
I assume that you hook up a new tach almost like you do a shift light.. by tapping into the computer and just splicing into the RPM sensor wire (I dunno if its a sensor, its a wire going to the computer that tells you waht RPMS you are at)
As long as you leave your original tach hooked up I don't see why they both would not work...
thanks. I want a shift light. I'm gonna go ahead and do alittle more research. sorry for the hijack lol
Old May 7, 2010 | 04:43 PM
0949er's Avatar
0949er
pat will I be able to T off the bottom? The top one doesn't have enough clearance to put a T fitting there (And get something on both sides)
np dude. Get a raptor. Worth the money, great quality. (And easy to change your settings and such, instead of having to adjust w/ resistors and stuff)
Old May 7, 2010 | 05:12 PM
nascrchi's Avatar
nascrchi
gotcha, actually this is exactly the light I was looking for. thanks again
Old May 7, 2010 | 06:27 PM
MustangMan00
Matt, we'll figure something out, I just know the bottom part is where you tee in to go to the vortech
Oct 7, 2015 07:02 PM
foxtrot
Sep 29, 2015 06:32 AM
Sep 18, 2015 12:25 PM
Demodulates
Sep 18, 2015 11:14 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
