factory 2 step?
factory 2 step?
went to the tuner today to get a inspection friendly tune, and he put into my tune a 2 step....didnt know you were able to do that just using a tuner...anyone else use this? i have the sct xcal2 if it matters.
and if anyone else uses it, could i adjust the launch rpm through my computer or is only my tuner able to do that with his software?
If you have a low level tuning system you can set these scalar values (click here) to set up a 2-step limiter. I have mine set at 2800 RPM, it's great fun...
It's safer than cutting the ignition and letting the injectors continue to "inject", however some claim the stability at the limit is better with the MSD limiter--I can envision this being true...
gotcha...so cliffy, if i check out the values on your link on my handheld, i should possibly be able to change my rpm? im going to have to look into this tomorrow...im fine with where it is set right now, but i would definately like to be able to change it if i feel the need
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
