What next?
Old May 7, 2010 | 03:20 PM
Kerns's Avatar
Kerns
Gears then tuner to correct your speedo and give you more hp.
Old May 8, 2010 | 12:33 AM
Z28KLR's Avatar
Z28KLR
Try to save a little more so you can get gears and tuner (or just get a speedcal for now) at the same time. I heard that if you drive around too long without recalibrating for the new ratio that it will throw the PCM off and send it into some sort of "protected" mode (not sure what that entails, but can't be good).
Old May 8, 2010 | 12:47 AM
sonicx's Avatar
sonicx
speed'n
You have heard correctly sir. +1 to both @ the same time or tuner then gears.
Old May 8, 2010 | 01:33 AM
Mustang3GT07's Avatar
Mustang3GT07
I say keep going with suspension. If you got springs on the way, do some CC Plates, Shocks/Struts, and Upper/Lower Control arms.
Old May 8, 2010 | 01:47 PM
Z28KLR's Avatar
Z28KLR
^^ Good point, I'd do (and did) some lca's at the same time as springs. You can probably get away without doing shocks & struts for now, depending on the condition of your current ones; but some good c/c plates should be in your near future for sure.
