coolant in my spark plugs #2 and #4
Old May 9, 2010 | 12:06 PM
timthegreat1's Avatar
timthegreat1
Default coolant in my spark plugs #2 and #4
so I pulled my spark plugs and found a bunch of coolant in 2 and oil and coolant in 4. I think its my valve cover gasket leaking, but im not sure my friends brother told me he would fix it for 150 hes a mechanic is this a normal price and is there a way to tell if it could be a head gasket. what does this sound like it could be to you?
Old May 9, 2010 | 12:16 PM
kugzgt's Avatar
kugzgt
check to make sure your lower intake isnt cracked! very common with plastic intakes
Old May 9, 2010 | 12:23 PM
timthegreat1
there's some coolant sitting above my lower intake but I cant see anywhere where It is cracked. I have a feeling that could be it any easy way of checking?
Old May 9, 2010 | 01:03 PM
MU71L4710N's Avatar
MU71L4710N
make sure your antifreeze is filled up then start your car, drive it around for 20 minutes, leave it running and pop the hood. when my intake cracked there was a very fine mist comming from under the thermostat housing.
also it could just be a bad o-ring. if you don't see any visible leaks you'll have to take it off and inspect the underside.
Old May 9, 2010 | 01:08 PM
timthegreat1
Ill try that. when I changed my spark plugs it ran fine for 2 days then went right back to bucking and running like ****. so I guess more got it
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
wraith777
Sep 28, 2015 10:49 AM
