Changing gear oil
Old Jun 4, 2010 | 10:02 AM
Jay-rod427's Avatar
Jay-rod427
Originally Posted by trailor
you can always syphon the oil out of there without removing the diff cover. i know i did. and as long as you don't go with synthetic oil, you will need friction modifier. i wouldn't recommend synthetic anyway, since the manufacturer spec. doesn't call for it
I would really like to know how you could effectively siphon out the old oil???
OP remove the cover bolts and remove the cover, clean out the housing and gears with brake cleaner, scrape off old gasket, reapply black silicon, replace cover, and fill from previously mentioned fill hole.
As far as fluid I recommend Royal Purple 75w140, there is no need to add friction modifier, and my 03 took 3 bottles for what its worth.
Old Jun 4, 2010 | 12:32 PM
Evenexchange's Avatar
Evenexchange
That's the fluid I'm looking at. Did it take just UNDER three bottles? I want to make sure I order enough...
Old Jun 4, 2010 | 12:35 PM
Jay-rod427's Avatar
Jay-rod427
Yeah just under 3 bottles(spilled a little) it is a massive pain in the azz to get the bottle above the diff to completely empty the bottle. I kinda wedged the bottle between the driveshaft and floor pan with a hose on the end into the fill plug.
You should be able to get that Royal Purple at most parts stores, I know O'reilly's for sure carries RP. Be prepared it does not come cheap.
Old Jun 4, 2010 | 01:22 PM
Evenexchange
Thanks. I know it's expensive lol. What did you mean by reapply black silicon?
Old Jun 4, 2010 | 01:31 PM
PurpleIcedGT's Avatar
PurpleIcedGT
Black Silicon is the gasket sealant...hey man are you really doing it yourself or are you gathering information?
Old Jun 4, 2010 | 08:19 PM
Repzard's Avatar
Repzard
To siphon it out you can use a hand pump.
Also same to fill it.
Something like this.
Old Jun 4, 2010 | 09:31 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
This is the "jiffy-lube" approach--at best you'll get 75% of the old fluid out, and 0.0% of the sludge and "normal wear" metal particles.
To do it properly you need to pull the cover and clean things out as Jay-rod described. That's why Ford did not provide a drain plug, a nice BIG drain and cleaning is what is needed...
Old Jul 28, 2010 | 10:25 PM
Evenexchange
Hey where do I get a new gasket for the rear end once I seal back up the differential?
Old Jul 28, 2010 | 10:40 PM
PurpleIcedGT
autozone
Old Jul 28, 2010 | 11:09 PM
travbedaman's Avatar
travbedaman
My diff cover was leaking and I used this write up that was really helpful. It helped me a bunch, Maybe it will help you.
http://www.bullittarchive.com/1005.htm
