Changing gear oil
Old Jun 3, 2010 | 04:28 PM
Evenexchange's Avatar
Evenexchange
Default Changing gear oil
I have changed my transmission fluid before, and I am wondering if the REAR END gear oil is a similar process (top fill plug, lower drain plug) I know you obviously can't fill the rear end gear oil through the inside of the car like you can with the transmission fluid.. lol
Anyways, how many quarts do we need of 75W 90? I have heard mixed things... Are there any special procautions to take when doing this change? I have a 2000 GT by the way, so I have the T45.
Old Jun 3, 2010 | 04:31 PM
Jay-rod427's Avatar
Jay-rod427
Transmission Gear oil, or Rear End Gear oil?
Old Jun 3, 2010 | 04:43 PM
Evenexchange
Rear end gear oil
Old Jun 3, 2010 | 05:18 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
There is no drain plug on the rear-end, you have to remove the cover to drain the oil. There is a fill plug on the front left of the housing.
For your 2000 the recommended fill/oil is 3.75pts of Motorcraft 80W-90 Premium Rear Axle Lubricant (which is probably no longer available), plus 4oz of friction modifier.
FWIW--the 2001+ specs call for 4.25pts of Motorcraft 75W-140 Synthetic Rear Axle Lubricant, plus 4 oz of friction modifier.
However as the axles are identical what this really means is that somewhere between 3¾ and 4¼ pints, of 75W-90 or 75W-140, dino or synthetic oil, with 4oz of friction modifier, will be OK (in my opinion).
But wait there's more! With some synthetic gear oils you may not need the friction modifier--check with the oil's manufacturer to find out for sure.
Old Jun 3, 2010 | 07:08 PM
GTRACER88's Avatar
GTRACER88
I put more than 4 oz of friction modifier. I believe I used a bottle and a half.
Old Jun 3, 2010 | 07:27 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Why?
If anything you'd want to use less to make the LSD clutches grab better...
Old Jun 3, 2010 | 07:33 PM
tbirdscwd's Avatar
tbirdscwd
so he can have an unlimited slip JK
Old Jun 3, 2010 | 08:22 PM
GTRACER88's Avatar
GTRACER88
Why?
This was in my girl friends 2002 explorer. May be different but with only one bottle the clutches still shuttered. They sounded like they were going to break.
Old Jun 3, 2010 | 11:50 PM
Evenexchange
So how many bottles of this would I need. Would this require friction modifier?
Old Jun 3, 2010 | 11:52 PM
trailor's Avatar
trailor
you can always syphon the oil out of there without removing the diff cover. i know i did. and as long as you don't go with synthetic oil, you will need friction modifier. i wouldn't recommend synthetic anyway, since the manufacturer spec. doesn't call for it
